Author Topic: Fuel line to fuel pump  (Read 716 times)
Offline isuras2
  • Name: R Swerczek
« on: December 06, 2021, 08:06:48 PM »
For the Cadillac 346, what should be used between the hard line and fuel pump in the engine bay?  I’m assuming just a regular fuel hose.
R. Swerczek
'47 Fleetwood Sixty Special
Offline wheikkila
  • Name: Wayne Heikkila
Re: Fuel line to fuel pump
« Reply #1 on: December 06, 2021, 09:21:08 PM »
Yes, a 3/8 " fuel hose.
 Thanks Wayne
Offline The Tassie Devil(le)
  • Administrator
  • CLC Number: 18992
  • Name: Bruce Reynolds
« Reply #2 on: December 06, 2021, 10:11:55 PM »
Make sure that you are using a neoprene hose, and not a rubber one, as the rubber one will degrade and cause you lots of heartache.
Offline harvey b
  • The truth is often a bitter pill to swallow
  • Name: Harvey Bowness
« Reply #3 on: December 07, 2021, 08:51:54 AM »
they used a short line with threaded fittings,it is about 6-8 inches long.it threaded into the pump and the end of the fuel line,i see them on ebay from time to time.It is a factory crimped line,the hose is braided also,you never would use a hard steel line as the vibration would cause it to crack over time. this is what they look like,not for a caddy but they all had a similar line.  https://www.ebay.com/itm/403255567141?_trkparms=ispr%3D1&hash=item5de3e7a325:g:eu8AAOSw~bhcEr9B&amdata=enc%3AAQAGAAACoPYe5NmHp%252B2JMhMi7yxGiTJkPrKr5t53CooMSQt2orsS%252BMKizvpuEDUfX4dvRWfUzQU%252BiGgSnQrZofiDq5zXO%252Fj3HeKDadvhP0R0eciYN7iEFB0TcEwtDiSnawqbflTzXwLN61lXj0qCRN7%252BiBFdDXrOi4nWGihQlvQX5QNE2QqbiDkqOjZfpithBeDN5le44vNW9ueVgJF0R7J7QRvxDO9KOMrG6fxvojE3j4b%252F0ci8v9mpgZkQim6wET3ekKkiWsEjdlhp1URD5FTB8TozYw%252FV05zVfSFYTt8BecCCYVDoKTq44peOP%252FlSADgdnhlDsDlze6BYeZp5sClgOkzKxHkDtATSZNIuObnmfufF3m3ABZdxZinP6fOzL2PiqeBkpL8gH8yflml4RaCAPD1jhdHEsddiMZwbesefl1lrFOnuKGMHsKfSrB4RRSbvZJ0MEQm6sU3QuJrUy6WO1ovHzUQpJ8h9BlcKRsJHw1uhOhSuBfEbQF2lnDXf2lgFFmx3ZlzuMH38aL173iYDEOj6uWBeFnziX0qyir96vU9ZrUYRPtSVuCW%252FF3knq%252Fv4wOXQoJiXeDZ8MiTAplKJP8Pa1zBLg7L%252FJYQaMrD6QF7aFp4N32iyuhX%252FYzvumBe6bMc3SscizOjah1F96CwJ%252Fctv25bUrj%252BAar4E7c3MloS2820TMXjWmQfdiCJl20LXyBtzxKtNIbOVsJOpLLJxPW1L96JehZa0y7GxuBT4eW815wy05gBbV4PLdknLL2femMckLfw4O4D%252BwRW1PihanNC1LK6rLWpYUZZ8zh2OvhC8eUQr4Kadh1T0xusB3EOv8h7KxXM0gAHFg4Lu3tINRE3N1qsDGvPqUCtBY3yWvGruFilfw6%252F5d9YtruldH6eSfNAVkg%253D%253D%7Cclp%3A2334524%7Ctkp%3ABFBM8NK_0rJf   harveyb
Harvey Bowness
Offline Jeff Hansen
  • Administrator
  • CLC Number: 4225
  • Name: Jeff Hansen
« Reply #4 on: December 07, 2021, 11:55:12 AM »
McVey's shows them as in stock for various year flatheads:
https://mcveys.com/collections/fuel-line-hoses
HTH,
Jeff Hansen
1941 6019S Sixty Special
1942 7533 Imperial Sedan
Offline Ohjai
  • Jim Conley
  • CLC Number: 32577
  • Name: James B Conley
« Reply #5 on: December 07, 2021, 02:45:12 PM »
Are the NOS hoses compatible with the new fuel we have?
Jim
'38 Cadillac Series 60 S
'41 Cadillac Series 60 S
2017 Cadillac CT6
'62 Buick Skyhawk Conv
'49 Bentley MK-VI  Sold
'53 Bentley R-Type  Sold
'66 Ford Thunderbird
'64 Rolls-Royce Silver Cloud III
'75 Rolls-Royce Silver Shad Sold
'78 Rolls-Royce Silver Shad II
'80 Rolls-Royce Silver Wraith II  Sold
'81 Rolls-Royce Camargue  Sold
'88 Rolls-Royce Corniche II
'89 Rolls-Royce Silver Spur
2020 Ford Escape
Offline fishnjim
  • Name: J. Bozin
« Reply #6 on: December 07, 2021, 04:43:08 PM »
I guess if you found a NOS hose, it'd be petrified by now, even if it was OK for ethanol, but was not.
I agree the short flex with end fittings is the way to go, and they'll make them out of fuel rated hose these days.(but check before you buy)
Motors move, so no rigid.   Do not use vacuum hose.
I use AN fittings sometimes and that's another option.  You can also make up hoses/have hoses made.   Much like a hydraulic but they use fuel rated
hose and fittings or AN style.   There's kits available at the race suppliers, usually braided hose.
