TIPS OF THE TIME!
Started by JIM CLC # 15000, April 03, 2005, 11:56:07 AM
JIM CLC # 15000
04-03-05
ALL Owners OF Used, Abused and Misused Cadillacs, La Salles and other Old Iron.
 Since most of the country set their time pieces ahead last night (or this morning) depending on where you were, you were reminded to change the batteries in your "smoke-detectors".
Very good idea, keep hearing about people dieing because of dead (no pun intended) batteries in their SD.
1. It is also a good time to check and top-off all "fluid-levels", tire pressures, air filter(s) in/on the old car and vacuum the interior of the "pride-n-joy". (maybe even wash-n-wax it).Also, take it for a Sunday Drive and show it off.
Good Luck, "happy-motorn", Jim
Rhino 21150
Might not be a bad idea to put a new battery in the car....
