96 sts brake lights
Started by harvey bowness, April 17, 2005, 06:07:59 PM
harvey bowness
my 96 sts brake lights keep coming on when the car is parked and no one is in it?,couldit be a faulty brake lite switch? also my heater fan does not work,on the climate control panel the little bars move when it is turned up,but the fan does not come on,my a/c is empty of r-134,we did a motor swap and had to remove the gas for that.checked the fuses and cant find one that is blown?. the brake lites when you step on the pedal the right inner tail lamp goes out when the brake lites .any help would be appreciated. thanks Harvey
George
If a light comes on, it is getting power from somewhere. The switch is the favourite. Remove the live from the switch and see if the light still comes on, if it doesnt, hey presto.
If the light at the back do tricks, clean all the ground connections. When you see a car indicators light up with the brake lights, or side lights flash when the turn signals are engaged. The problem is usually a ground fault at one of the lights.
