77 Brakes question
Started by Sid Bartos, June 26, 2005, 05:47:07 PM
Sid Bartos
Hi i have a question about the brakes on my 77 cdv..
the other day i noticed that when i pressed the brake pedal it made a noise like an air leak or (sshhhh) then more recently its becoming harder to stop and i still hear the noise. it started doing this the day i got it back from the the garage with a problem that was started when they didnt install hoses with a new fuel pump correctly. maybe something happened when they were looking for the problem? does anyone know what this can be?
thanks, sid
Tod - North TX CLC
Sid -
Sounds like it is in the power booster.  Check under the hood, and make sure that the vacuum line from the booster to the carb/intake is in good shape and properly attached.  Without full vacuum, you will get a hard pedal.
If the vacuum source is good, it may be that the booster has gone bad.
