All Cads
Author Topic: 6 volt auxillary electric fans?  (Read 1627 times)
Dave Leger CLC#19256
  • Guest
« on: June 27, 2005, 10:14:02 AM »
Hi Folks,
   I recall mention in an copy of the Self Starter earlier this year that someone was going to be producing 6 volt auxillary fans again.  Does anyone have contact information on the company producing these?  Having watched a few cars overheat in recent parades, I am trying to be proactive, before my 1947 6207 starts making public appearances.
Dave
Ralph Hoyt
  • Guest
Re: 6 volt auxillary electric fans?
« Reply #1 on: September 09, 2005, 11:01:01 PM »
Did you ever find a company that produces the 6 volt fan
Ivan Zanatta
  • Guest
« Reply #2 on: September 12, 2005, 12:05:50 AM »
If you cant find a 6 volt fan, try 2 small 12v fans in series.
 This  trick works with some 6 volt equipment. (horns, ETc.)
Ivan
Ivan Zanatta
  • Guest
« Reply #3 on: September 12, 2005, 12:09:57 AM »
OOps! disregard my last message, I was typing faster than I was thinking. I have just finished a 6 to 12 volt conversion and this trick will notr work in your case!
Sorry!
David Leger CLC #19256
  • Guest
« Reply #4 on: September 12, 2005, 09:59:25 AM »
Hi Ralph - no, no one has dropped me a note, and I havent run across a supplier yet.  Ive been busy with winterizing the house, so to be honest, havent done any hunting lately for one.
Dave Leger CLC #19256
  • Guest
« Reply #5 on: September 14, 2005, 08:41:11 PM »
Ralph - I did another wbe search tonight, and there is now a supplier who came up (primary application Chevrolet, but hey, a fans a fan).  They have 14 fans in pusher or puller styles.  Check out http://www.macsradiator.com/index.asp?PageAction=VIEWPROD&ProdID=69
Frank 21888
  • Guest
« Reply #6 on: September 25, 2005, 05:55:50 PM »
Two resistors in parallel reduce the voltage, not in series.
jack oconnor clc 18960
  • Guest
« Reply #7 on: September 27, 2005, 06:45:12 PM »
 There is a six volt fan on the market. Scott fans have what you are looking for. The have a webb site. Get the largest fan that will fit. It will work well for parades. I have used there fan for a few years without any problems. My engine drivin fan has been removed. Good luck -   jack
