1996 Eldorado Squeaky Doors - Help
Started by Tim, July 09, 2005, 07:20:23 PM
Tim
Anyone have experience in this area? Both of my doors in my 1996 Eldorado ( ETC ) squeak when the glass is all of the way up. I have lubed the rubber around the doors, however they still make an anoying squeak. Almost sounds as though the glass has too much pressure on it. Strange that both doors would have the same squeak. I welcome any advice. Thanks, Tim
Rusty Shepherd CLC 6397
Very long, heavy coupe doors (and yours definitely fit that category) tend to sag with age which could cause the squeaks.  When opening the doors from the outside, check to see if they drop a bit as they move away from the body. There are ways to shore them up, but they are not always completely successful.
Also, check the weatherstripping.  If its really dry and crumbly, itll need replacing. If its just dry, douse it really well with a silicone lubricant and repeat every six months or so (also treat the weatherstripping around the hood and trunk...its unlikely to require replacement as its not explosed to the elemenets nearly as much as around the doors).
Tim
Thanks Rusty. I did take another look at the surrounding door/window rubber and foam molding and discovered that I had not applied scilicone spray to the upper areas of the door seals. I am on day two of a quiet vehicle again. Thanks for the tip and the response.
Tim
