Founded 1958
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Forum Rules
Calendar
Login
Register
CLC Home
Forum Rules
Technical / Authenticity
(Moderators:
Lars Kneller 8246
quadfins
Barry M Wheeler #2189
Bill Hedge CLC 14424
brake calipers
All Cads
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: brake calipers (Read 1431 times)
mike butler
Guest
brake calipers
on:
July 11, 2005, 12:33:20 PM »
please help....Ive got a 1997 cadillac deville up on jack
stands to change brake pads...done it many times but, never on a caddy....problem...ive got calipers off (hose still connected)
and want to depress brake cylinders down to allow for new pads....they wont move...neither side will depress(using c-clamp and old brake pad) they just wont move...is there some trick???are the cylinders just frozen open???i dont want to force them if im not doing it right PLEASE HELP
Logged
JIM CLC # 15000
Guest
Re: brake calipers
Reply #1 on:
July 12, 2005, 03:30:29 AM »
07-11-05
Mike, have replaced pads on an 86, should be about the same as on a 97. I used a C clamp to compress the pistons back, it took some force to over-come the initial move-but after that, it was smoove sailing.
HTH
Good Luck, Jim
Logged
Bruce Reynolds # 18992
Guest
Re: brake calipers
Reply #2 on:
July 12, 2005, 03:33:30 AM »
Gday Mike,
Are you talking about the Rear or the Front Brake?
Bruce,
The Tassie devil(le),
60 CDV
Logged
Sam L. Moore CLC #21210
Guest
Re: brake calipers
Reply #3 on:
July 13, 2005, 11:26:36 AM »
Are you working on the end of the car that the emergency brakes are on? Im not sure about your Cadillac, but some vehicles require that the caliper pistons be rotated out if the e-brake cable actuates the caliper piston. If so, auto parts stores carry an inexpensive tool that you can put on a socket extension to rotate them or you can improvise.
Logged
mike butler
Guest
Re: brake calipers
Reply #4 on:
July 14, 2005, 11:03:12 AM »
gday to you bruce
im talkin about front brake clipers...they dont seem
to want to depress, and im afraid of forcing them...
also about to pull rear brake discs and noticed theres only one bolt on bottom of disc assembly and a rubber insert on top....what gives??
thanks a lot for your help, you down under devil, you
mike
Logged
Print
Pages: [
1
Go Up
« previous
next »
(Moderators:
Lars Kneller 8246
quadfins
brake calipers
Sitemap
1
2
3
4
5
6
7
8
9
10
11
12
13
