92ac, problem
Started by Art#22010, July 13, 2005, 08:25:37 AM
Art#22010
   My 92sdv is while running ac, leaking water under dash. Ac is cooing fine. Some water is exiting under car, however, whats exiting under dash should be going outside. Water is clear.
Can anyone point me in right direction. Maybe I can fix myself.
cant afford to put in shop right now and drop a grand. No leaks when off, so I guess I could drive without air if need be. Thanks for any help. Art
JIM CLC # 15000
07-13-05
ART, what you are seeing is condensation from the air. Most likely the drain tube/hose is becoming clogged, run a length of wire or some other stiff snake in the tube to un-clogg it. (just dont be under the tube-out-let when you do it!).
Good Luck, Jim
