1999 Cadillac Rear Air Shock Question
Started by Vinny CLC # 16477, July 19, 2005, 03:26:08 PM
Vinny CLC # 16477
Does Anybody know where the air pump for the rear air shocks are located on a 1999 DeVille base model?  I want to chek it before I replace my shocks.
BigDonno
Under the right rear, just inboard from the wheel. Wear eye protection.
If its the air strut that's bad, they are very expensive from GM.
Do a google or ebay search for Arnott replacements. Excellent quality and only $300 or so for the pair.
You need a large Allen or torx socket for he top of the shock, it will just spin if you try to undo just the nut.  If you didn't know that I just saved you an hour.
The original question was writen in 2005...I doubt that that guy was sitting and sitting until the answer came!
I certainly hope not.
I don't usually look at the original posting date. If it says "new" I just assume its new.
