1930 tech questions..
Started by Mark Burnett, August 02, 2005, 09:43:35 PM
Mark Burnett
Well...I have a 1930 353, which is a very original car. however I see no provision for an air cleaner on this car. I once has a 31 model with the same carb, but ir has a j tube and air cleaner attached..was this not offered in 30? Also, is there supposed to be some sort of shroud above the intake manifold? Last question, I have heard somebody makes a brass float and modern needle-seat for this carb, if so, where can I get them, and who has any replacement window cranks, door handles?
Thanks, Mark Burnett
Andy Wietzke
Quote from: Mark Burnett on August 02, 2005, 09:43:35 PM
hello Mark
I have a 1930 Cadillac 353 All Weather Phaeton style 4380. Are you interested in changing informations and pictures ?
regards  Andy
