Hi, You do not state whether or not you are a CLC member. If you were, you would have a Directory of other members who have similar cars, some possibly near you. It is more likely that you could get the bolts and fasteners you need from a private source that has the time to get them. You must realize that a "business" has to charge for their time and going out and getting rusted (possibly) bolts from a junked car is not cost effective, and quite simply, no one does this unless they get them themselves by going to the parts yards. Also, most parts vendors do not have "kits" of bolts and washers available. You need to go out to your local hardware store and simply purchase the ones needed. I just checked a 1960 era Master Parts Book and it does show the sizes needed on the grill cradle area, which would be one of the areas you seem to need. So get a Master Parts Book, and part of your problem should be solved. The specialized fasteners, you are going to have to either find a parts car, or hunt them up at swap meets like the rest of us. I was at the Auburn swap meet a week ago today and there was a vendor who had nothing but fasteners from all makes of cars. Check in Hemmings Motor News. Most of these vendors would advertise in that publication. I hope this helps. Good luck.
