Control Cable Question
Started by Dave Leger CLC #19256, September 14, 2005, 09:14:47 AM
I have a defroster control cable which had broken on my 1947 6207.  The outer metal sheath is in good shape, just the steel wire core broke long ago.  Does anyone know where I can get such steel wire to re-core the control cable, or barring that, where I could pick up control cable by the foot?  Web browsing hasnt turned me up anything, other than the idea of picking up one of those universal choke kits and scavenging the core from that cable.
Mike #19861
 Cables can be made, and are commonly done in the industrual sector.
 You could contact a local lift truck or materials handling shop and ask them who makes cables for them. Im sure this will give you at least a lead.
Dave Leger CLC# 19256
Thanks Mike - thinking about mechanical (non-automotive) uses gave me a new line for web searches, and I found a supplier.
Bruce Reynolds # 18992
Gday Dave,
I have used hood cables in the past to construct control cables, but you have to use the ones with the solid wire, not the wound type.
They are long enough to make up about anything.   Doing RHD conversions, the original cables are never long enough.
Bruce,
The Tassie Devil(le),
60 CDV
Bruce - thanks for the suggestion.  By the way, Ive been down your way to Hobart before.  Beautiful country there.  (I work in the U.S. Antarctic Program, and was in port on one of our research icebreakers)
Dave
Dave,
Next time you are in port, give me a call.   I live on the other side of the river and am in the phone book.
Bruce,
60 CDV
Mike #19861
 Glad you found something.
 Its amazing the world of industrial suppliers. You can find a lot of stuff there that you would not dream of.
 For instance, if you have a power steering hose that has gone kaput, then take the assembly to one of the industrial hydraulics suppliers and they can make you up a new hose using the original ends usually while you wait for a fraction of the cost. The same goes for AC hoses.
