Soda Blasting
Started by Bob 13906, October 12, 2005, 10:08:16 AM
Bob 13906
Does anybody have any experience with soda blasting ? Can a regular sandblaster unit be used? Thanks, Bob
I had the entire body of my 1956 Fleetwood soda blasted with terrific results.  Metal was smooth as a babys butt, and soda leaves a protective coating that prevents rusting until you can prime and paint. Had a shop do it - not sure if they use different nozzles etc, but apparently soda isnt coarse enough to do heavily rusted items like frames, as quickly as silica. Mike
Tom Beaver CLC 22002
Soda blasting takes special equipment, either with air or water.  The equipment is not cheap nor is the soda.  I have a soda hydroblaster which I have used on aluminum and it works well.  I have also hauled my 38 coupe to a shop and had it air soda blasted, as the price they quoted was about what the soda would have cost me.  The results are very good, however, it will not remove rust.  It will take off loose scale, all paint, plastic body filler (if its not to deep) as well as dirt and grease.  It can also warp thin soft aluminum tags and plates so remove these before having the body soda blasted.  If you have it done take the body off and have them do the underside as well because this will save you a lot of time and aggravation later.
Good luck.
