Need info on 99 Northstar water pump
Started by Philip Swanson Member #18013, November 04, 2005, 02:25:48 PM
Ive been trying to track down a minor coolant leak for a couple of months and finally , I think Ive traced it the pully that looks like its on the back of the water pump. Dose anyone know whare I can get some info on the Northstar Engine? Also dose anyone know if this is common with a Northstar with less than 70,000 miles? Thanks for any info.
David #19063
We had the waterpump replaced on our 96 Concours when it had around that mileage, luckily we had purchased an extended warranty.
Pedro #20411
   The Northstar waterpump is supposed to be relatively easy to replace. It unscrews from its enclosure & you screw the new pump back in, you will need a special tool though. Check out the GM shop manual or one of those Chilton guides if you can get one. There is also a Cadillac forum on the internet that is also helpful for information.
