brakes
Started by Art#22010, November 24, 2005, 08:06:04 AM
Art#22010
Have a leaky brake cylinder.
  Better to rebuild or replace.
  If rebuild, need to hone or not?
  If I do one, should all be done or as needed.
             Thanks Art
Porter 21919
Art,
I just did my 67 brakes, one new wheel cylinder from Napa was $ 62, I got the rebuild kits and the hone tool from Napa, all for $ 45. Saved enough money for shoes, hoses, spring kits and grease seals.
An easy job to hone them out and replace the center spring and rubber seals/boots.
Porter
