antilock warning light on
Started by Robert Bothwell CLC # 20850, December 14, 2005, 10:20:01 AM
I recently replaced the rotor and pads on the rear of my 96 Deville. After letting the car down, I test drove it to make sure the brakes were acting normally. The warning lights for the traction control and antilock brakes are on while they were not before. The weather has been cold so I have not yet checked the fuses. Is there anything else to check when I get to it?
 Robert
Mike #19861
 Check to make sure you have not disturbed the sensor or ant related wiring for the ABS/TCS, thats where I would start.
 Otherwise you will need access to the shop manual and a scanner to properly locate the problem. You will likely have to take it to a qualified shop to have this done.
