95 eldorado struts and car wash prob.
Started by kruser, December 18, 2005, 06:53:01 PM
kruser
anyone know if there is a cross over for standard econo struts and shocks instead of the powered factory option?
also ran through a car wash yesterday and the engine seems to be sputtering and missing. plugs? coils?
any help greatly appreciated
David #19063
Kruser,
I do not know about the shocks (but would be interested to learn).  What does Cadillac say?
Usually when I have seen problems with missing and sputtering after a car wash, spraying off and engine, or after splashng through a deep puddle, it has been old bad wires.
Is your car a Northstar or 4.9L?
When I had a tune up done on both my 96 Concours and my 94 Fleetwood Brougham, I made sure they used OEM plugwires from Cadillac only.
I have heard that aftermarket ones can be troublesome and then youll end up paying to have Cadillac ones installed later.
David
kruser
Thank you for the info
I did pull the coil pack and blew out with air and seems to be fine.
After posting, I found a company that makes a cross over for 499.00. (Strut Masters)  Compared to OEM its a steal.
RKruse
