V12 interchangeability
Started by Michael Lepak 17679, December 20, 2005, 08:58:20 PM
Michael Lepak 17679
Does anyone know if the 1931-1937 V12 engines are interchangeable within these years?  i.e.-would a 37 model year match up to a 31 transmission and bellhousing in a 31 car?
In the listing of technicians there is no one named who specializes in this engine.  Is there anyone who has worked on these I could talk to?
Thank you,
e-mail:
mikel1@charter.net
Barry M. Wheeler #2189
Try either Carl L. Steig of San Leandro, CA, or Ted Raines, also of California. Both have restored several V-12 engined cars. Their phones are in the Directory.
Philippe M. Ruel
Hello,
from the 1935 edition of Motors factory parts price lists
* 1931-33 370-A, -B and -C cylinder block, with fitted pistons, rings & pins was rated $94.50
* 1934-35 370-D identical part was $98.40
It means the part is not the same and will certainly feature different casting numbers. Unfortunately my book does not show parts numbers.
Of course it does not mean a later engine wont mechanically fit an earlier transmission or engine compartment.
Hope this can help.
Mike #19861
But were the blocks not separate units from the crank case? That would be where the trans bolts up.
Warren Rauch
  My 9th edition Hollander (1940) says 31-35 are the same and 36-37 are the same. From Cadillac parts book Crankcase part numbers 1091393(1931),1096001(1932-33)1096285(1934-35),1096518(1936) sorry I dont have 1937. Warren
Michael Lepak 17679
Thank you, gentlemen, for your assistance.
I now have some good leads to follow.
Bob Hoffmann CLC#96
I believe that all the V-12s have the same pattern for the bell housing. There are differences in the crankcases. The 31s have no fuel pump. The 32/33 has a float for the oil level. The 34 and later has a dip stick. Hope this helps. Bob
