1970 Tranny Linkage: Which one?
Started by Kevin Bielinski, January 13, 2006, 11:48:05 AM
Kevin Bielinski
This photo has the bolts marked #1 and #2. The book has lousy pictures and lousy instructions. Which one do I loosen to adjust this transmission? The car is a 70 DeVille
http://www.kmichael.freeservers.com/Copy_of_TrannyLink.JPG TARGET=_blank>www.kmichael.freeservers.com/Copy_of_TrannyLink.JPG
denise 20352
I vote for #2, so you can slide the rod and make it longer or shorter.  Youre adjusting the shift linkage, right?
-d
Kevin
Yep, I was told to play around with that in order to solve my PARK problems. If that does not work, I need a new bushing.
