Gold plated 50s Cadillac V application=help ?
Started by Jeff Maltby #4194, January 21, 2006, 11:00:30 PM
Jeff Maltby #4194
13.5 tip to tip with 2 finger notches underneath. CV is the only # underneath.
Thanks in advance
1949 fastbacks rule :<)
Philippe M. Ruel
I have a 1952 trunk Vee at hand, from a 1952 60 Special, which is 13.6 tip to tip, gold plated, with two notches.
The angle is approximately 120 degrees inside (top), 110 degrees outside (bottom).
At the back, right side (seen from back) in the middle compartment I can read 10 145904 2 embossed. 2 is circled.
These Vees were chromed (not gold plated) before 1952.
Part #s are:
350 9570 for 52 Series 60 Special
350 9571 for 52 Series 62 except sedan
350 9572 for 52 Series 62 sedan and Series 75
I dont know the difference between them.
It seems 53s shared the same part #s as I cannot find any decklid emblem update in my 53 parts catalog supplement.
Jeff Maltby #4194
Thank you. I have 2 of these gold Vs but only CV is apparent, with no #s. My 50 decklid V clearly states a part #.
HMMM?
Ed Dougher
Gold anodized would actually be correct on the car, not plated as many vendors sell.
