All Cads
Author Topic: Jet Hot exhaust?  (Read 1462 times)
Doug
  • Guest
Jet Hot exhaust?
« on: February 05, 2006, 10:57:44 AM »
Anyone know what this is?  Thanks Doug  22747
Ivan Zanatta
  • Guest
Re: Jet Hot exhaust?
« Reply #1 on: February 05, 2006, 06:21:05 PM »
Gday,
 Try this Australian site; www.jet-hot.com.au
Its an exhaust (header) coating which is popular over here, it probably originated in the U.S.,
Looks great and never rusts, Ive got a couple of sets lined up to get done.
Bruce Reynolds # 18992
  • Guest
« Reply #2 on: February 05, 2006, 07:02:53 PM »
Gday Doug,
Plus, it is a really good coating to protect a custom-made exhaust system from rusting away too soon.
There is nothing worse than spending hundreds of hours building a set of pipes, only to have them rust out in a couple of years.   Been there, done that.
Bruce,
The Tassie Devil(le),
60 CDV
Doug
  • Guest
« Reply #3 on: February 06, 2006, 07:21:57 PM »
Thanks Gents - - youre right on target.  The seller volunteered that it was a coating of sorts on the exhaust pipes running atop the old flathead V-8.  Doug
josh
  • Guest
« Reply #4 on: February 07, 2006, 05:41:42 PM »
Try a company called HPC for good coatings also. I just had my 390 manifolds done in "stock"looking cast iron finish for $225. they look great but havent tried them yet.
Matt Mersereau
  • Guest
« Reply #5 on: February 07, 2006, 10:40:32 PM »
Hundreds of hours Bruce!?! That must have been some set of pipes!
I too have heard good things about Jet Hot coatings. Its not cheap, but then again nothing worth having comes cheap.
Rhino 21150
  • Guest
« Reply #6 on: February 10, 2006, 07:03:17 PM »
If you are looking for this sort of thing, try here.
http://www.afipowder.com/ AACA just had an article on this company and their ceramic coating. Porcelain is what they used in the thirties, but it is too brittle to last on an engine.
