Look into Diamondback tires. Ive heard good stuff, but I didnt see triple ring WW in the PDF catalog. I seem to recall bias ply tires develop flat spots when sitting for extended periods, so you may want to take that into consideration. I just think radials are much safer to drive on when the sh!t hits the fan.
Heres a little blurb from the diamondback site about radials vs. bias ply.
Because of the Ford-Firestone problems of 2003. the Department of
Transportation has created the new FMVSS 139 (Tread Act) for the purpose of
“establishing new and more stringent tire performance requirements that apply
to all new tires for use on light vehicles.†Here is the DOT’s assessment of the
differences in performance characteristics between bias and radial tires.
“A bias passenger car tire carcass is typically made up of two or four plies of
cord material that run from bead to bead at an angle of approximately 35
degrees to the centerline of the tire. Alternating plies are applied at alternating
angles during the manufacture so that the cord paths of alternating plies crisscross.
This type of construction provides a very strong, durable carcass for the
tire. However, it has drawbacks. Because the ply cords criss-cross and all the
cords are anchored to the beads, the carcass is stiff and relatively inflexible.
This type of construction prevents the different parts of the tire from acting
independently of another when forces are applied to the tire. As a result, a bias
construction is susceptible to impact breaks because it does not easily absorb
road irregularities.†This causes more rim stress.
“By comparison, a radial passenger tire carcass is typically made up of one or
more plies of cord material that run from bead to bead at an angle of approximately
90 degrees to the centerline of the tire. As a result, the cords do not
criss-cross. Because the cords do not criss-cross and because the opposite
ends of each cord are anchored to the beads at points that are directly opposite
each other, the radial tire carcass is flexible. The radial tire is reinforced and
stabilized by a belt that runs circumferentially around the tire under the tread.
This construction allows the sidewalls to act independently of the belt and the
tread area when forces are applied to the tire. This ‘independent’ action is what
allows the sidewalls to readily absorb road irregularities without overstressing
the cords. Impact breaks caused by cord rupture do not occur in radial-ply
passenger car tires. This ‘independent’ action also allows two important things
to happen during cornering: 1) the tread of a radial tire remains fully in contact
with the road over the entire tread width, and 2) the ply cords and sidewall are
able to absorb the cornering forces without exerting the twisting force on the
beads that are exerted by bias constructions.â€
Bill Chapman
President
Diamond Back Classic Tires
Source-page 1149 CFR Part 571
Docket # NHTS-030-15400
RIN 2127-A154
www.nhtsa.comRims vs. Radials
Old Wives Tale or Fact?
Call today! 888
