Never use PAG unless youre replacing everything and flushing the whole system. If the system has any trace of mineral oil or R12 in it, and you have to add oil with R134, the correct oil to use is Ester.
One of the mistakes that the Las Vegas XXXX XXX shop made to my car was to add PAG to my system without removing all of the ester oil. The compressor was already beginning to seize when they gave me the car back.
Also, there are three different grades of PAG, so if you are doing the whole system, be sure to use the right one.
-denise
