What ATF for 59 hydramatic?
Started by Robert, May 03, 2006, 02:33:05 PM
Robert
Hi,
I want to replace the fluid of my 59 SDV hydramatic - the manual says ATF heavy duty, what does this translate to in modern terms?
Greetings
Robert
Jim Eccleston CLC 16079
Robert
Hi,
which Dexron?
Theres Dexron II and III
Thx
Robert
Paul Flykt CLC # 18899
Either Dexron II or III is OK. There was quite a discussion on this a couple of years ago. I emailed AC Delco at that time and was told Dexron transmission fluids are backwards compatible all the way back to the type A that was used in the 50s.
I just checked the extra bottles in my garage - Dexron III.
peter
Hi I just use the synthetic ATF in my Hydramatics.It makes them shift smoother and better.Also the trans will run cooler!!!around 20 less on a real hot day.
Peter
Jan CLC #17589
Hi, I wonder, if Dexron III is a improved verson  of Dexron II, why do they still manufacture and sell Dexron II ?
Jan
