proper fuel
Started by glenn brady, May 03, 2006, 10:18:16 PM
glenn brady
I own a 72 Eldo with 97K miles. 500 V8. What is the proper fuel to run in it ? The prior owner told me 1 tank hight test, then 1 tank normal (87) octane.
Someone else told me I needed to add a leaded addititve.
denise 20352
  87 octane unleaded is fine.  In the summer, with the air conditioner on, you might want to use 89.  Any more octane is just a waste of money.
-d
Rusty Shepherd CLC 6397
Also, you will definitely not need a lead additive.  All 1971 and later GM engines were designed for unleaded gasoline.
