1937 Lasalle transmission
Started by Michael Conner, May 24, 2006, 07:24:26 AM
Michael Conner
P.S. What is the shift pattern for this car? 1st, 2nd 3rd Reverse it seems to be in a straight line? Where is reverse? Thanks Mike
JIM CLC # 15000
05-24-06
MIKE, The N position is the cross-bar of the H. Anorther
way of saying it is when you shift from R to 1st, you must go thru the Cross-bar of the H, also when going from 2nd to 3rd, you must go thru the cross-bar of the H. HTH
Good Luck, JIM
