According to the 38 manual, which should apply to your coil as well: Run special tool J-726 (looks like a knife blade to me) between the cap and the coil to loosen it. Is your coil upside down? Thats to keep water out of the top (bottom). Anyway, they are talking about the base of the coil which has a metal cap. When its loose, gently pull the coil out and unplug the wire thats in there. The ignition wire is armored to limit theft attempts. But there arent any punks who know this so you might not need to re-install the armor assembly. BTW: to hot wire this car, roll under the dash and put a jumper (heavy) from the hot side of the ignition switch to either side of the ammeter. Everything should work, including the starter. Dont raise the hood, its too conspicuous. Yeah, I know a couple of car thieves.
