1949 Cadillac
Started by Jerry Bell, July 01, 2006, 10:49:18 PM
Jerry Bell
Could someone tell me how to check the oil on a 1949 Cadillac automatic transmission. I just bought one and dont know how. Thanks so much.
art#22010
passenger side front carpet, peal it back towards the seat cushion. Everything will be exposed at that point.
Jerry Bell
Thanks so much for the info, it was helpful!
cadillacman
Hi does the engine have to be running or can you check it cold?
Chrome is my favorite color!
Raymond919
Check the oil while the engine has been running and hot. Check the fluid in neutral. If you have the shop manual it tells you to check it in drive. That's a mistake.
Under the carpeting, is a metal disk about 3 inches in diameter. It has to be popped out to get to the little transmission dip stick.
