1949 Cadillac
Started by Jerry Bell, July 07, 2006, 08:48:12 AM
Jerry Bell
Could someone tell me what kind of transmission oil to use for a 1949 Cadillac? ( automatic )...Thank you, Jerry Bell
Paul Flykt CLC # 18899
Modern Dexron transmission fluid will work. It is backwards compatible, meaning IV replaced III that replaced II etc.
I could open a can of worms here and suggest type F. Some older transmission mechanics feel the new Dexron fluids are too slippery for the clutches and recommend F because they feel it is more like the the original type A.
There was a very comprehnsive Dexron vs F discussion a year or 2 ago on this forum. Some members opting for either type apparently without any problems because of their choice. Personally I use F in my 57 CdV on the advice of the older mechanic that did the overhaul and have had no problems. I use Dexron in my 62 sedan because that was what the prior owner used.
John Morris
Ford trannys ran hotter and used type F. The 49 Hydramatic had no cooler so type F might be prefered??
