95 Seville STS power window switch
Started by Rudy Streng, July 10, 2006, 10:31:56 AM
Rudy Streng
The switch for the drivers side power window will no longer work.  I would like to attempt this myself and wondered how to access the innards.  I know if I pry up the plastic cover, it will break for sure.
Any suggestions?
Thanks in advance.
Rhino 21150
There are fasteners on the back of the door panel, which you must remove. Ewwwe. Very annoying job.
