Hello!
My Cadillac has been waiting patiently for 37 years for me to get serious about restoration.
Last week I took the body off the frame and am working on cleaning off years of rust and grease from the frame.
For those of you not familar with a Fleetwood body, getting the body in the air was different from a normal car. The body and floorpan are not one piece items all welded up. There is a large red oak plank down each side of the body. These are separated from the support points with large, thick rubber insulators. Then the body A pillars, "B pillars and rear areas are bolted through metal mounting points, through the wood planks and the metal support brackets welded to the frame.
The floorpan is then screwed to the wood planks rather than being welded to the rest of the body. Fortunatly, the planks in my car were good enough to support all the body weight while lifting it off the frame. If these planks were totally rotted out, a 60s would be a flimsy car indeed.
I need to find out how to post pictures to share my experiences with the rest of you. More later,
Bob B.
