Transmission Fluid
Started by Mike P, August 21, 2006, 06:48:39 PM
Mike P
I am having a problem finding type A fluid.......is there a substitute?  I have a 1955 Series 62 with a Hydramatic Transmission???/   Thanks!
JIM CLC # 15000
08-21-06
Mike, According to a post by a PAUL FLYKT on 05-04-06 @ 3:24PM he said that DEXRON II or III is OK. Suggest you use the search function associated with the Forum Index and search for tranmission fluid, or Goggle it.
HTH
Good Luck, JIM
Jose Gomez CLC # 23082
Mike,
Ive posted the following reply back on 3/22/05 (see below)regarding the Type A transmission fluid. Per Jims suggestion the search feature is available to research on previous postings.
Good luck..!
Long time ago I posted a message on this site regarding this topic, I also included it the following URL for Warren Oil Company that carries Type A trans fluid http://www.warrenoil.com. TARGET=_blank>http://www.warrenoil.com.
The have several manufacture locations and any one closes to you could provide you with a local distributor.
I found a Wholesale place in the Dallas area that also carries the Type A (not from Warren) and I purchase a case for around $14. Good luck..!
Jose
