1928 Cadillac Tire Compressor
Started by Ken Andersen # 21420, August 24, 2006, 05:35:16 PM
According to my Cadillac Parts List for 341-A, the tire compressor has a part described as:-   Coil on Tyre Pump for Air Cooling.  From the illustration in the book, it would appear that this part may be a small coil of copper tube, which fits onto the top of the compressor piston chamber at the air outlet. There are several loops of tube, then a vertical shaft about 4 inches ( estimated ) long, to which the air hose is fitted.   My compressor only has the nut that connects this to the air outlet with about 1 inch of copper tube.
Can anyone provide a photo of this part.
Also, what type of handle fits onto the riser shaft at the top, to engage the compressor. The parts book does not show this part.
