Glasurit 22 Line Single Stage?
Started by Brett 21441, September 04, 2006, 12:08:29 AM
Brett 21441
Hi,
I was curious if anyone has seen/shot glasso 22 line single stage?
It is still available in solid colors.
Brett
Lou CLC19028
Yes, Glasurit 22 line is still available in solid colors. Seen,sold and sprayed it. 22 line is one of the best automotive finishes available anywhere in the world. It is the OEM brand of paint for Mercedes and BMW. As far as spraying it , your best results will be to spray it in a booth because of its high solid content. Little things like door,trunk jams can be sprayed on the floor but anything larger than that will require a controlled environment.
Happy painting,
Lou
