Buying new carpet
Started by Jack Miller, September 23, 2006, 01:53:26 AM
Jack Miller
Hi All,
I am looking for a nice original style carpets for my 1961 Cadillac convertible.
Is one seller better than the other?
Are they all using the same material and with prices all over the place?
How are the ones on Ebay?
I am new at Caddys and I am doing this 61 solo from mechanical to body & paint work. (I will send out the top)
I am not doing a chassis off but I did scrape down the chassis and repaint and the same with the underbody.
There was no rust on the floor boards or from the doors back.
I did have some water get in and I just had to pull out all of the carpet and under felt and sound deadening material as it stunk and I didnt want to ruing the floor boards.
Tomorrow I will remove the surface rust on the inside floors, por-15 or rust encapsulator and paint them as they only have surface rust from this water.
Jack
Fred Garfield 22310
Hi, Jack - Lots of us have had unhappy experience with POR-15. It just doesnt hold up over the years, cant be touched up and is a bear to remove. After you get the pans clean with Oxysolv (or whatever rust remover you use) and a wire attachment on a drill, try painting painting them with zinc phosphate and top-coating with Zero-Rust.
Jack Miller
Thanks Fred,
I will look into that
Jack
