Window Installation Urgent - 1928 Cadillac 7 Seater
Started by Ken Andersen # 21420, December 10, 2006, 02:27:31 PM
I am at the stage of my restoration, where I need to order & install new windows.
My Fisher Body Maintenance Manual does not show how the windows are installed into the door.  That is, there are no pictures or explaination as to what window tracks are used, whether there is a timber garnish mould installed after you install the window tracks etc etc.
Is someone in the CLC able to offer me advice and photos so that I can correctly install the windows.
Still floating around awaiting some information.  Thanks Guys.
Warren Rauch
I took a look at the 26-31 repro-manual and it sure is bad. The earlier 1927 manual shows it much better , for wood framed doors. Your car doors are wood frames?,not steel? The copy I have was from a Pontiac-Oakland dealer ,but should be the same for all Fisher Body. I dont know how to get you copies in a timely manner. Warren
Dear Warren,
Thanks for your reply.  Perhaps you could run off a photocopy of the pages that apply to the window frames, scan it into your computer, (if you have a scanner) and email them to me. Or, send the photo copies to me in the post. I am only now starting to finalise the door, having fitted all of the door hardware, and am now working on the timber inserts.
I have basically timber framed doors, however the main front door piller, the one that the windscreen and header board are connected to, is steel of course.
I am a few weeks away from completing the window timber trims, and obviously cannot procede with this part of the restoration, until I can work out what side and top channel is used, ( I believe that it is rubber), and I also believe that this is complemented with a timber trim ( garnish moulding ) between the rubber channel and the inside edge of the window frame.
Dear Warren,
Sent you and email message, sure hope that you got it, and can assist me.
Thanks & Regards
Ken
Warren Rauch
Dear Warren,
Thats very much appreciated Warren, hope that I can return the favour in the future.
Best Regards
Ken
