34 Cadillac hard shifting on 3rd gear
Started by Tony #22054, December 29, 2006, 01:32:48 PM
Tony #22054
I tried double clutching it but it wouldnt work. The gear grinds and I have to force it in. I put 85w/140w gear oil. Is this too thick? What do I need to check before taking the transmission apart? Thanks
Wayne Womble 12210
Two things usually cause hard shifting.  Bad synchronizers and a clutch that will not release fully. Since it is only third gear, I would guess the synchronizer. The blocking ring may be cracked.
Tony CLC#22054
