Founded 1958
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Forum Rules
Calendar
Login
Register
CLC Home
Forum Rules
General Discussion
(Moderators:
Lars Kneller 8246
quadfins
Barry M Wheeler #2189
Bill Hedge CLC 14424
hood springs
All Cads
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: hood springs (Read 3327 times)
Joe Bento #20081
Guest
hood springs
on:
January 19, 2007, 11:33:35 AM »
Howdy!
Anyone have a source for hood springs for my 1940 Series 72?
The more, the merrier!
Logged
Doug Houston
Guest
Re: hood springs
Reply #1 on:
January 19, 2007, 05:58:54 PM »
Check Inline Tubes website. I think they have hood springs. They can also make a new handbrake cable for you.
Logged
Joe Bento #20081
Guest
Re: hood springs
Reply #2 on:
January 19, 2007, 06:07:08 PM »
Thanks Doug!
Their website appears to be down at the moment. I will try again later.
In the meantime, any other locations? Any idea how much does it cost to make a pair of springs?
Logged
Joe Bento #20081
Guest
I didnt see it
Reply #3 on:
January 19, 2007, 11:27:35 PM »
Doug,
I didnt see anything on inline tubs website about springs.
Any other suggestions?
Thanks!
Logged
Chris McBride
Guest
Re: hood springs
Reply #4 on:
January 22, 2007, 09:12:32 AM »
I have not used this vendor but previously saved its info for future reference:
http://ll.hemmings.com/pdfs/SMSAutoR230074.PDF
http://sms-auto.com/smsauto/public/en/index.html
HTH
Chris McBride
Logged
Joe Bento #20081
Guest
Re: hood springs
Reply #5 on:
January 22, 2007, 09:41:59 AM »
Thanks for the lead Chris.
I had already contacted these folks and they could not help. The led me to another source called LS Hood Springs, but they basically said they dont have any in stock and dont intend to have any more made.
Does anyone have a parts book handy? Maybe you can tell me what models these springs will interchange with. I have a 1940 series 72.
Thanks!
Joe
Logged
Paul Ayres #5640
Guest
Re: hood springs
Reply #6 on:
January 22, 2007, 10:38:46 AM »
Joe - You are in luck. The springs are the same on all 1940 Series 52, 62, and 72. Cadillac part number 1436993. Paul
Logged
Ev CLC17806
Guest
Re: hood springs
Reply #7 on:
January 22, 2007, 07:59:11 PM »
Joe! I suggest you try calling USA Parts Supply Ltd at 1-800-872-2013, 8AM-8PM EST Mon-FRI. I purchased a hood spring for my 76 Caddy and it was real good. Try and see what they got. Good Luck! Ev
Logged
Joe Bento #20081
Guest
Help!
Reply #8 on:
January 30, 2007, 10:46:39 PM »
Hi again!
Still no luck tracking these down.
Cmon folks! I cant be the only one here who has ever needed these. Anyone have a secret source (or stash) of hood springs for a 1940 Caddy?
Anyone...anyone...Bueller..Bueller..Bueller.......
Logged
Rob
Guest
Re: Help!
Reply #9 on:
January 30, 2007, 11:05:04 PM »
When my 47 cadillac hood spring broke, I mailed the 2 broken pieces to a shop that manufactures springs and they made me a nice matching set of 4.
I did not find any part shop that stocks those.
Maybe Kanter can help.
Rob
Logged
Jerry
Guest
Re: Help!
Reply #10 on:
January 30, 2007, 11:21:59 PM »
Try Honest Johns Caddy Corner in Denton, TX. He might be able to help you out. Prices are very fair and service is very good.
Logged
Joe Bento #20081
Guest
Re: Help!
Reply #11 on:
January 31, 2007, 09:07:59 AM »
Hey Rob,
Do you happen to remember the shop and how much they charged?
Logged
Joe Bento #20081
Guest
Re: hood springs
Reply #12 on:
January 31, 2007, 11:57:11 PM »
Howdy!
I found a place that can make the springs, but there are a couple of problems:
1) The cost to make four springs is about $350.00 Most of this is set up.
2) The cost for 10 springs comes to about $50.00 per spring
3) They can produce the spring to the dimensions of the original, but since the original is broken, they can not test what the "resistance" is of the spring.
So, does anyone else need springs? Does someone else have another source?
Thanks!
Joe
Logged
Rob
Guest
Re: Help!
Reply #13 on:
February 01, 2007, 12:56:56 AM »
The shop in question is not in the US. They charged me about $20 per spring including galvanization. no matter how many spring I ordered. not sure about the "resistance" but if your replace all of them that should not matter too much. the thickness came out exactly the same.
Looks like should be able to find a cheaper place, maybe a small family type shop that has the equiment to do smaller quantities and dont charge too much on setup.
Rob
Logged
Jack Mcilwraith
Guest
Re: hood springs
Reply #14 on:
February 01, 2007, 09:23:06 AM »
Joe-I have a couple of springs from a 1946 62 series,which I dont need.I dont know if they would fit, but you can have them for the postage cost.They are 8 3/4" from hook to hook[end] and 1 1/8" across.I can take a photo and scan it to you if you like.
Logged
myren kohlhorst
Guest
Re: hood springs
Reply #15 on:
February 01, 2007, 01:42:22 PM »
Joe, I researched this spring problem about 5 years ago for my 39-6119. I would belive that your hood is the same size and weight. these springs are nothing like what they use for the outer hinge/ spring hinges. There pull is shorter. Im at work now and only have a little info I can share. These springs are called (extension springs),the origionals were made of .160 dia. wire and had 38 coils wrapped in 1 inch diamameter and a relaxed length of 8 1/2 inches with crossover hook ends. I measured my old ones (that would not hold up the hood) and went from there till I found some that were better and they work fine. Here is what I found. There is a free length, (8 1/2)a(initial tension) the pounds of force it takes to seperate the coils from each other and the working pounds of force every inch of deflection. These springs work at 10 1/2" to 11 1/2" of extension.
My old springs were in order of the above:
IT=35#
9 1/2"=60#
10 1/2"=110#
11 1/2"=155#
The new are .180 dia.wire,35coils,1.140 diamater X 8 1/2 long,
IT=45#
9 1/2"=80#
10 1/2"=120#
11 1/2"=180# You are working a total of 240-360 pounds of force to hold up that hood. Next is to try and find where I bought them 5 years ago. Off to the box of reciepts tonight. To be contuned;
Myren
Logged
joe bento #20081
Guest
Re: hood springs
Reply #16 on:
February 02, 2007, 08:48:25 AM »
Thanks Myren!
I gotta admit, the technical stuff blows me away, but if you have a source for springs that will work, you are my new best friend!
Joe
Logged
Paul Anisman
Guest
Re: hood springs
Reply #17 on:
February 02, 2007, 09:28:05 AM »
Joe - Try Kirk-Habicht Co. in Baltimore.
Heres the link:
http://www.kirk-habicht.com/
Theyre an appx 100-year-old operation that makes nothing but springs. Ive dealt with them (although not for an automotive application). Theyre an outstanding outfit...and reasonable.
Be interested to hear if you hit paydirt with them.
--Paul
Logged
myren kohlhorst 17794
Guest
Re: hood springs
Reply #18 on:
February 02, 2007, 12:17:53 PM »
Joe,
Id call these people that Paul suggested and give them the information on the springs. Ask them if they can send you a couple of samples. I looked last night for
Myren a reciept but no luck. I have a couple of places for my reciepts after 6 years on my restoration.
Logged
Joe Bento #20081
Guest
Re: hood springs
Reply #19 on:
February 02, 2007, 04:31:01 PM »
I will give them a shout and report back!
Thanks!
Joe
Logged
Print
Pages: [
1
Go Up
« previous
next »
General Discussion
(Moderators:
Lars Kneller 8246
quadfins
hood springs
Sitemap
1
2
3
4
5
6
7
8
9
10
11
12
13
All Cads
