1948 Series 75 Imperial Sedan
Started by Kevin M. Gillette, February 20, 2007, 04:50:28 PM
Kevin M. Gillette
I have a few interchangeabilty questions regarding the following parts:1) grille and hood 2)taillights 3)bumpers.
Are these interchangeable with the 1947 or 1949 75s? Thank you.
Barry M. Wheeler #2189
Strange...The hoods all show different part numbers, that I would have thought were all the same. Tail lamps are all the same, including 1941. Grilles are all the same. Rear center bumper sections are all the same for 46, 47, 48, and 49 75. In fact the ends are the same for all series, but stay away from the Series 61 just in case. It wasnt quite clear on that model. Re: the hoods. Cadillac would show a different # if you moved a screw hole. Jeff, our web master might be able to shed some light on this.
Kevin Gillette
Thank you. That opens up a few other possibilities.
Kevin
