Where to buy small replacement parts?
Started by Eric, March 30, 2007, 05:19:33 PM
Eric
Hi Guys,
Where do you guys typically come up with your replacement parts for your older Cadillacs?  I referring to parts like distributer points and caps, plug wires, voltage regulators, starter solenoids, correct battery cables?
The only catalog place Im aware of is Kanter, but as far as I know they dont have some of the smaller parts like that.
So, where do you guys shop?
Eric
Jerry
Depends - - what era vehicle do you own?
1940s 1950s 1960s 1970s?
Doug Houston
As already asked:  Whaddya need?  A good place to start is the NAPA stores. Even I am often amazed at the things they sell, and many of us head there first. Recently, I needed a set of rebuild kits for all brake cylinders on one of my 41 Cadillacs. Got em all there. Sometimes they need to special order the things, but they can get a lot of stuff.
Bill Gauch #23121
In addition to what Doug and Jerry said, it also depends on whether you want a replacement/repair part or a NIB/NOS/NORS part. A local auto parts store has replacement parts. Some junk yards have some good stuff and many are starting to sell online/mail-order. EBay is always an option. As for vendors, Coopers Vintage has a good list of parts, although apparently they (he) doesnt respond to the e-mail listed on the site. You can find some stuff that will interchange at Chevys of the 40s. Wiring stuff can be found at a place like RI Wire. It really depends entirely on what you want. Post a request for something and usually someone can point you to a possible source.
Eric
I have a 52 Series 62.
Ill check NAPA and the others mentioned.
Eric
Johnny #662
Let me give another "vote" for NAPA.  When I recently replaced the belts and hoses on my 85 Eldo, they had them.  The hoses were molded ones, not universal type, which gives an original appearance to the engine compartment.
Geoff Newcombe #4719
I have to vote for NAPA first also, then Coopers at .....
http://www.coopersvintage.com/ TARGET=_blank>http://www.coopersvintage.com/
You might also try Rock Auto at http://www.rockauto.com TARGET=_blank>www.rockauto.com
or McVeys at ..... http://www.mcveys.com/ TARGET=_blank>http://www.mcveys.com/
Kanter seems to have a lot of stuff but would not necessarily be my first choice.
As the others have said, it depends on just what you need.
