I bought two 1954 coups and all ready started stripping and cutting one down, In January the main body and chassis will be started on, I'm rebuilding everything that I don't have from scratch, I'm only using the 50% of the frame, 80% of the nose. 90% of the doors, and 40% of the Quarters. Now this one is going to be a real as can be 1953 Le Mans....
Dear Mr. Frank, I am thrilled that LeMans #2 will live again in replica form! While the research was being done on the four LeMans for David Temple's book, we nicknamed LeMans #2 as "Raven" to keep the cars apart in our discussions. So good luck on Raven-the Motorama Gods are smiling! Charles D. Barnette
Quote from: Jack Frank on December 20, 2007, 01:21:26 PM I bought two 1954 coups and all ready started stripping and cutting one down, In January the main body and chassis will be started on, I'm rebuilding everything that I don't have from scratch, I'm only using the 50% of the frame, 80% of the nose. 90% of the doors, and 40% of the Quarters. Now this one is going to be a real as can be 1953 Le Mans.... Interesting story! I have however a question: why do you use a 1954 Coupe for that revival? Would not be more wise to use a 1953 basis for that project as 1954 to 1956 belong to another generation?Anyway, congratulation for that very interesting task.RogerSwitzerland
Quote from: Roger Zimmermann #21015 on December 22, 2007, 06:43:58 AMQuote from: Jack Frank on December 20, 2007, 01:21:26 PM I bought two 1954 coups and all ready started stripping and cutting one down, In January the main body and chassis will be started on, I'm rebuilding everything that I don't have from scratch, I'm only using the 50% of the frame, 80% of the nose. 90% of the doors, and 40% of the Quarters. Now this one is going to be a real as can be 1953 Le Mans.... Interesting story! I have however a question: why do you use a 1954 Coupe for that revival? Would not be more wise to use a 1953 basis for that project as 1954 to 1956 belong to another generation?Anyway, congratulation for that very interesting task.RogerSwitzerland Spell check scrambled some words and deleated some word on my last reply? To answer your question, take a look at the 1953 LeMans Concept car then look at the 1954 coup, the 54 inharited its looks from the LeMans, the 54s fenders only fit 54s, the 55 and 56 are differant even thoe the tailights are the same. the 1953 Cadillac coup is intirely differant. Jack
Quote from: Charles D. Barnette on December 21, 2007, 02:49:55 PMDear Mr. Frank, I am thrilled that LeMans #2 will live again in replica form! While the research was being done on the four LeMans for David Temple's book, we nicknamed LeMans #2 as "Raven" to keep the cars apart in our discussions. So good luck on Raven-the Motorama Gods are smiling! Charles D. Barnette Thank you for the great compliment Mr Barnette, so what where the other three names of the Le Mans ?
Well he goes another question.....................A few years ago I toured the Peterson Museum next to the Tar Pits in L.A.............and there was a Lemans there, metalic Sebring Silver with a silver or medium gray interior, the seat had smaill 1/2 " rolls and pleats, quad headlights and Eldorado Brougham tail lamps 57/58 type fins...................which one of the four is this car, it was also for sale in Hemmings at about $300K by L.A. car dealer Frank Corrette ( Not sure of the last name spelling)...............again where does this one fall ?.................Thanks, The 64 ELDO Guy. I think this one was also in an Elvis movie..............Lots of sectioning the car had, great lines........................Where is the FLORENTINE experts ?.
......... What should I call this car? ..... reborn, recreation, I need to start a new post cause its here...............
Well here is an update, on my 1953 LeMans as you can see there is no turning back now with this much cut out I hope to have the rest of the doors the cowl and floor cut by this weekend, then send all the puzzel peices to sand blasting........... What should I call this car? ..... reborn, recreation, I need to start a new post cause its here...............
Quote from: Jack Frank on January 24, 2008, 10:57:54 PMWell here is an update, on my 1953 LeMans as you can see there is no turning back now with this much cut out I hope to have the rest of the doors the cowl and floor cut by this weekend, then send all the puzzel peices to sand blasting........... What should I call this car? ..... reborn, recreation, I need to start a new post cause its here............... Very interesting Jack. I wonder how you will rebuild all the pieces together. The view remembers my '56 convertible when I had to remove the rear fender to clean the rust. The floor you are showing seems in very good shape, much better than mine was.Good luck,Roger
