Early rearend 1920s ?
Started by Earl, April 29, 2007, 04:45:42 PM
Earl
Hi,
I recently found  a rearend from a Cadillac at an old farm over a bank, at first I was going to use it for a doodle bug, but I feel it may be to valuable to use for that application. The brake band goes around the drum and they are bronze it has what I call a traction bar attach near the center which I am sure attached to the fram once apon a time, also aluminum caps on the axles. What does it go to? what is the value?
Earl Leighton
Not a club member at this time
