1931 V12 Model 370-oil on rear brakes
Started by Paul Richfield, May 05, 2007, 10:00:48 AM
Paul Richfield
Has anybody had hands-on experience with the making of these seals.There are 2 types,just outboard of the differential there are leather seals to stop the oil going down the trumpets and at the outer end there are felt seals rubbing on the Brake drum inner hub to stop any grease from the hub bearings spraying onto the brake linings.Any help/info gratefully recieved Paul.[paul.richfield@cegetel.net].
Wayne #17075
I removed the seals on my '30 Lasalle and took them to Napa and found modern replacements that fit perfectly and are much more reliable.
Wayne
