Attention 1969 and 1970 Deville Owners. I need help, please!!!!!!!
Started by Vinny, June 28, 2007, 10:28:30 AM
Vinny
I have converted my 66 Devile to front Disc Brakes using a factory setup from a 1969 Deville.  My question is, when routing the brake lines, do the front brakes get routed to the front chamber of the master cylinder or the rear chamber of the master cylinder(and vice versa for the rear)?   I know I have to use a prop valve.  If you 69-70 owners can look under your hood and tell me, I would be greatly appreciative.
George UK
A Dual master cylinder is used. The front reservoir supplying rear brakes and the rear one supplying the front brakes.
Quote from the Chilton manual.
