1940 Wing vents
Started by Suzuki Joe, August 29, 2007, 12:22:17 PM
Suzuki Joe
howdy!
I have a couple of questions surrounding the wing vent windows for a 1940 Series 72.  Right now they are in the chrome shop to be polished/plated, but this is a complicated assembly with parts of this assembly being stainless, and parts are diecast:
1) several of the parts are rivited.  How do we go about seperating them, polishing/plating, then reattaching?
2) there is alot of rubber around the perimeter and it looks like it was vulcanized to the frame.  What do I do with this?  I can't tell if Steele Rubber has this piece, or does it have to be sent out to be revulcanized.
Any and all thoughts and suggestions are appreciated.
Joe Bento
1940 Cadillac Series 72
Antoinette Blue (or a close resemblence thereof)
Style: 7223
Bill Hamilton, CLC#16219
Joe,
Steele has both the main seal and division post seal for you car. About $140 for both windows. Neither is vulcanized to the door frame or divider post. The main seal is a pressed in fit. The divider seal requires removal of the main window run channel from the divider post to remove and install. I replaced all this on my 42 75 series car. If you have a 40's body manual it will show how to disassemble the frame from the actuator.
Bill Hamilton
Don Boshara #594
The upper pivot pin can be reattached with stainless or chrome plated brass flat head rivets which a good hardware store should have, and the lower one with pop rivets.
1940 Sixty Special
1966 Mustang Cpe
