George
Many thanks, I will try this, I think this is the type of problem you get with a recently restored car, the engine is still quite tight.
As you say the car fires first turn but then stalls, if you hold down the pedal to try and keep the revs up it is no better, only repeated turning over of the engine starts her, she runs rough but heats up after 30 - 60 seconds and runs well after that!
I follow the recommended starting procedure in the handbook, one pump and start without foot on gas etc
Regards
