Back in the fifties, Dynaflyte dual point breker plates were popular for about any engine's distributor. They had a very good ball bearing suspension, and were highly sensitive to the action of the vacuum advance. As already explained, they made ignition more efficient.
I have installed a Dynaflyte plate on one of my '41 Cadillacs, and it worked well for a while. But, the cam follower blocks on the two point sets wear at different rates, even as similar as you can get them. That involves re-removing the distributor and re-adjustment at closer intervals than you'd check single points. This is done on a distributor machine. As good an idea as the dual points were, they became sort of a nuisance, and I removed the second set of points, left the Dynaflyte plate on it, and went away contented.
While the dwell angle will drift normally with single points, it becomes more critical with the dual points, and always wants to be out of adjustment. You'll probably never feel the difference with or without dual points.
