Author Topic: "50 rear bumper/License plate lamp assembly question  (Read 1590 times)
Joe G 12138
  • Guest
« on: November 04, 2007, 11:15:37 PM »
Is there supposed to be a gasket or rubber piece between the license plate bracket/ light assembly where it bolts to the rear bumper on the '50-52 cars? Or is it metal to metal?  Thanks.....Joe
Offline rghobden
  • Name: Russ Hobden
Re: "50 rear bumper/License plate lamp assembly question
« Reply #1 on: November 06, 2007, 12:36:09 PM »
No, you shouldn't put a gasket there.  I think this was one of the few design flaws on this car; they depended on too many good clean and tight contacts between the license plate lighting assembly and the bumper to ground the license plate light. I counted at least six contact points, all of them prone to rust or corrosion, dirt, loose bolts or screws, etc.  I ran a separate ground wire from the lamp base directly to the trunk floor, thus eliminating several potential problems.
Russ Hobden, CLC #1235
All Cads
