Hi, I have a 1973 Eldorado which I beleive came with air ride level control as standard. Ive located all the system on the car, it seems to be all there however the suspension doesent readjust with heavy loads. The car sits properly with no pasengers or loads but with 3 or more passengers it is low enough to scrape the muffler on speed humps and curbs etc.
I was wondering if there was any way of manually setting the rear suspension permanantly on high. there is a valve- (the same as you'd find on the tyres-) on the compressor/tank under the hood. Im imaging that if i attatched a tire pump to this it would eventually find its way down the lines to the rear shocks. does any one know if this or similar is possible? Thanks.
