Probably. Is there a lot of play in the gear selector lever?
So now it does not crank no matter what you do? Do some of the lights go off when you turn the key to start? If you turn on the headlights and or the dome light do they seem to dim at all when you turn the key to start? Im wondering if if maybe the key is not pushing the switch far enough to get it to the start mode or if you have a bad switch.
Quote from: TJ H on December 10, 2007, 09:27:49 AMSo now it does not crank no matter what you do? Do some of the lights go off when you turn the key to start? If you turn on the headlights and or the dome light do they seem to dim at all when you turn the key to start? Im wondering if if maybe the key is not pushing the switch far enough to get it to the start mode or if you have a bad switch.First off let me ask a general question: Do you all mind these types of questions? I have used other forums to figure out problems with my furnace, plumbings etc and sometimes the professionals would get sore about the DIY types. I just want to be sure I don't step on any toes. That said I'll check it out tonight. It a convertable so its short a some light but if I leave the door open I'll watch the lights in the wells.
